swapping terrashark swing arm to a 16" T-Bolt frame, possible?
Lam
26 Jan 2010 11:11 PM
I own a 18" EPX complete with terrashark swing arm. After two rides in the trail, I find the 18" EPX virtual horizontal top tupe is too long (almost 60cm) for me that I have to stretch out both arms to reach the handle bar. To have a tighter "cockpit", I am thinking of swapping the terrashark swing arm to a 16" T-Bolt frame (as called in Malaysia). Has any bike mechanic or someone you knoe of done this before in Malaysia? Thanks in advance.
mickey
28 Jan 2010 11:32 AM
i think it can be done... coz the frame for epx n t-bolt is the same.. i have an 16" t-bolt with alloy swing arm... would u like to swap/trade the carbon swing arm with the alloy one?
mickey
28 Jan 2010 11:34 AM
owh btw, where r u? i'm in Malaysia..
28 Jan 2010 07:08 PM
Hi Lam,
You could try some the below tweaks before removing the terrashark swing arm. It might help!
Lowering your seat or adjusting it forward...
Alternatively change to a shorter stem 80mm or less. Shorter stem does help reduce the stretch.
hanaz
05 May 2010 07:39 PM
Lam, u could view Malaysia Bicycle Buy N Sell, there's a guy named Azrool offering 16" frame c/w spring DNM shock. I'm staying in Rawang, and if you insist to let go your existing carbon swing arm, I am willing to swap it with you.
