tz350
 New Member Posts:34
| 29 Apr 2007 04:58 PM |
After a lot stuffing around with different CNC machine shops we now have the new shock mounts for the Terrashark in stock. These new mounts allow for the use of a 190mm long shock with 50mm of stroke to give 156mm or rear wheel travel. Ride height is increased and the frame will also need to be matched with a front fork with a travel around the 130mm mark. This mod realy makes the Terrashark more freeride competent. Mount will be supplied with shock bolt and nut and will cost $47.50 AUD plus $8.50 AUD for post to anywhere in the world. |
loh
 New Member Posts:1
| 04 May 2007 05:15 AM |
nice........
can I get the rear carbon fibre swing arm with that?
 New Member Posts:23
| 10 Feb 2008 10:39 PM |
| hello, im new here and dont know where to go for one of these new shock mounts, can someone let me know if i can still get one? thanks!! |
tz350
 New Member Posts:34
| 10 Feb 2008 11:23 PM |
| I have them in stock. Email me at evan@epxbikes.com for the details. Your shark looks sensational. Evan |
 New Member Posts:23
| 13 Feb 2008 02:29 AM |
| hello again evan, i tried emailing a couple times so i figured id hit ya up on here again, can you email me an invoice w/shipping to pa. and can i pay with paypal? THANKS!!! carbonrrpilot@yahoo.com |
cheekeon
 New Member Posts:1
| 16 Feb 2008 08:31 AM |
| Hi, i have a Proton T-bolt, thinking of converting it for freeride ...... but the rear swing is aluminium and is slightly different from your graphite ones .... is there anyway I can bolt on your updated shock mount for a 190mm shock with 50mm stroke. Does the front need to have 135mm travel can I use it with 80mm travel instead? |
tz350
 New Member Posts:34
| 16 Feb 2008 01:40 PM |
Hi Pete, I sent a couple of emails on the shock mounts. Also hi Ang, The shock mount will fit the T-Bolt. You will need a 130-150mm travel for to match the upgrade. Evan |
t-rex
 New Member Posts:2
| 27 Mar 2008 09:56 AM |
yes evan...please send me the details......thanks
momoyluds
 New Member Posts:4
| 12 May 2008 12:32 AM |
Hi Evan,
I have a Marzocchi All Mountain 2 front shock with 150mm of travel, will I need to change my fork if i make this upgrade?
-Marty
PS I've done some technical single track which had some steep DH sections with my Terrashark with my new Marzocchi fork, the bike is amazing, soaking up everything I ran over. Thanks again for all the help. |
momoyluds
 New Member Posts:4
Hi Evan,
-Marty
sampahsembilan
 New Member Posts:5
| 15 Jun 2008 11:13 PM |
i want one!! |
a$hm3y
 New Member Posts:7
| 16 Jun 2008 11:00 PM |
| me too!!! |
kelolo
 New Member Posts:18
| 21 Jun 2008 10:05 AM |
Whoa...T-Bolt owner from Malaysia with alu swingarm...Before you decide to get this extended shock mount, do check the clearance between your swing-arm and FD. Mine is only 2mm. Not possible to have longer travel fork as it will slam-bam-thank-you-mam your FD. How about those with carbon swingarm? Any FD clearance issue? |
sampahsembilan
 New Member Posts:5
| 24 Jun 2008 02:27 AM |
ive checked the clearance its like u've said..just a merely 2mm but for the shox mount i think is ok cuz it just extended the shox length that can be fitted at the swing arm the clearance not an issue i guess
kelolo
 New Member Posts:18
| 25 Jun 2008 04:01 AM |
Yeah...can anybody confirm that installing the extended shock mount does not push the swing arm down? And what's the suitable shock length to be used? |
a$hm3y
 New Member Posts:7
| 25 Jun 2008 05:47 PM |
| 7.5inch is the ideal.. you can choose many branded shock and even the fox dhx can be used.. just make sure eye to eye is 7.5in(190cm).. kelolo, i've seen your blog man, quite interesting.. good work!! |
adrianlim
 New Member Posts:4
| 16 Jul 2008 10:25 PM |
| hai there,,,, everyone, m a newbieeees here,,, just got my bike 2 weks ago and i've also got few friends got the same bike,,,, i'm new with all the height ride so n so,,, plsdo teach me whn i'm blur. |
nitebleed
 New Member Posts:1
| 09 Sep 2008 02:24 AM |
Did any proton t-bolt user change the mount yet? Any different with the rear travel after change the mount?
james lau
 New Member Posts:2
| 11 Nov 2008 01:55 AM |
hi , i am james here ,i am a t-bolt 16" user , may i know where can i buy the updated shock mount & carbon swin arm ? it cool
rmcbeath
 New Member Posts:1
| 25 Aug 2009 04:00 PM |
Hi, Can you let me know if the 190 mm shock mounts are still available, and if so who to contact to order one. Thanks, Randy |
